| Author / Post |
wildblueyonder  Lifetime Site Supporter
United States Posts: 214 IP Logged
| Posted: May/20/2016 at 9:25pm |
Hello All -
My name is Mohammad and I live in suburban Chicago. Have been out of the hobby for about 8 years now and now easing back into it. I am planning to finish my trainer which has been sitting on my work bench for the last 6 years. But I have been thinking about building RC a scale model, but not sure which one to start with since I am a newbie and would like to build an easy one.
Thoughts?
Mohammad
Admin  Admin Group
United States Posts: 5975 IP Logged
| Posted: May/20/2016 at 9:49pm |
Hi Mohammad,
Some good options for a first scale model build would be something like a PT-19, a Moth Minor, or a similar light wing loaded tail-dragger before moving into the "heavy-metal" birds. Once you get your trainer flying and get used to it, you might find a tail-dragger sport plane kit to get used to flying a tail-dragger before graduating up to a larger heavier model. I am sure others will chime in and offer their suggestions the main thing is to get very very comfortable with flying an r/c model before moving into a larger heavier scale model.
Good Luck! Mike
Sparky  Lifetime Site Supporter
United States Posts: 8140 IP Logged
| Posted: May/21/2016 at 8:44am |
Mohammad,
Welcome to RCSB! As Mike wisely said get something floaty for your first scale plane. Several ARF's are to be considered, the Piper Cub and several like that would be a great place to start.
Just because it is a ARF doesn't mean you can't add more scale details like a pilot or instrument panel. Change the markings to a plane that you might find on line or in a magazine.
What Chicago area club do you fly with?
| Posted: May/28/2016 at 9:03am |
Hi Mike and Sparky -
I used to belong to TriVillageRC, and flew at a field in Hoffman Estates. I have attached a few pictures of my Hobbizone SAFE Cub, which I am currently flying. And other pictures of my trainer which I need to finish and take it up in the air.
With Gratitude Mohammad
p.s. pardon me for the inverted images, couldn't figure out how to orient them.
| Posted: May/28/2016 at 10:15am |
Mohammad,
I think your third plane being a 3D plane is a bit too optimistic.
We have had several club members wear out those little Foam Cubs most were much heavier with all the 5minute epoxy and duct tape. When they finally went in the bin. But excellent training.
The wood trainer you have will be a good second plane then if. You think you are ready for a3D plane find a less expensive foam plane to try out it will be shocking to go from a conventional trainer to a 3D plane.
Sorry I'm not familiar with the clubs you mentioned but find a mentor and he should be able to help you along a successful path.
| Posted: May/28/2016 at 10:43am |
Hi Sparky -
Thanks so much. Are you in Chicago?
J_Whitney  Moderator Group
United States Posts: 7552 IP Logged
| Posted: May/29/2016 at 8:34pm |
Mohammad, I agree with Sparky. 3D aerobats are very very neutral - not self-righting or stable like your trainers. By all means for your 3rd airplane move to a low wing, but as Sparky said a 3D will surprise you, and it would be better to be surprised for less money!
Setting up a good 3D plane is an art form in itself, too.
__________________ Jeff
| Posted: May/29/2016 at 11:53pm |
Hi Jeff -
Good point, staying away from 3D's for now :) This is trainer of mine is turning into a challenge of its own. Since I haven't worked on it in 8 years, I have spent two days looking for parts in different nook and crannies of my house
