Home>Forums>Vendor Announcements>Flite-Metal Customer Projects Search Within This Topic
Posted: May/16/2026 at 7:46am  Quote
forum imageforum image
forum imageforum imageforum image
Posted: May/17/2026 at 6:13am  Quote
2.
forum image
Posted: May/17/2026 at 10:43am  Quote
Does Flite metal have to be applied over a Fiber Glassed surface?
Posted: May/17/2026 at 11:03am  Quote
Any composite material...G10, epoxy, polyester, plastic, smooth non-grain surfaces.
............................................................ ..................forum image
............................................................ .......Click Me
Posted: May/17/2026 at 11:08am  Quote
Would it work over thin Birch Ply sealed with Water based Polycrylic?
Posted: May/17/2026 at 11:26am  Quote
You were headed to the best skinning solution with G-10 "at the proper thickness" adhered with the "proper adhesive" for the desired cure time. The fuselage is a cylinder...
Call Henkel and ask what would be best... Do not ask another modeler...the reply will only be relative to what "they needed...then did"...either failing or working. Ask Henkel.
Posted: May/17/2026 at 12:31pm  Quote
 I don't have enough of the thin G-10, and the curves at the Tail of the fuselage are too tight for that even if I had enough.
It was very expensive. I drove to Fort Worth to get it. Shipping was out of the question and still is.
Going to stay with thin Birch Ply Panels for the Fuselage and probably the Wing Center Sections, then 3/16th Balsa for the rest of the Wings.
That's the plan now, we shall see if that works out.
Flite Metal Contact
Flite-Metal Contest Winners Show How...
Flite-Metal Q&A...Ask Questions Here
Flite-Metal 25% Sale Through Feb 22
