Home>Forums>Show Your Stuff!!!>Fokker DV11 Search Within This Topic
Avatar User Offline thecoles
Posted: September/18/2022 at 3:03am  Quote
Hi all,
I haven't been doing much of late with covid, moving house, settling in, changing jobs (X2) and sorting the workshop etc. I just haven’t really been much in the mood for my models but I feel things are changing now and am slowly getting back into it.
 I thought I would start by showing my DV11 which I built 10 plus years ago. I designed and built it before I was a member here so no build thread was done. I thought I would show it off here as it is one of my better builds that has really served me well. I will try to keep the story brief and not bore you too much and I only have a few pictures of the build so will show all I have of it.
So the story, it started with a conversation with a good friend who is a bit of a WW1 buff, he has a few fokkers in his collection but no DV11 so he decided that I should build one as my next model. He gave me a set of drawings by Air Age Inc, copyright by Joseph N(can’t read the rest), anyway on the 3 view it gives all the dimensions and measurements of the full size so I set about drawing a full size plane in TurboCad. I had already decided to do a ¼ scale so I decided what size material I would use for the fuse frame, wing spars etc and drew them onto the plan 4 times bigger than required so once the plan was finished and reduced to ¼ scale then everything was the right size. The drawings were fairly basic but I understood them and that was all that really mattered and the rest was made up as it all came together.
The fuse was built mainly from dowel from the local hardware and ply around the front end and where I thought it needed a bit of extra strength. Front panels and louvers are litho and I made molds for the radiator surround and lower front panels. The wings etc are all made from balsa, rib sections are from the 3 views and scaled to suit with under chamber. Both main wing incidences are set to zero and tailplane is set to the same as the full size, undercarriage is internally sprung with bungee cord within the undercarriage wing and wheels are homemade. Power is provided by a Moki 180 with a 18/10 prop and home made header pipe and muffler, not a rocket ship but adequate for the job, flies like a big trainer and any looping type maneuvers have to be started from a bit of a dive. Final flying weight is 24lbs. Hope you enjoy the few build pics I have, thanks for looking in.
Steve.
and the final product.
Take offs are optional, Landings are mandatory.
Steve.
Avatar User Offline Henri
Posted: September/18/2022 at 3:36am  Quote
Beautifull, nice scheme too.
Avatar User Offline fwman1
Posted: September/18/2022 at 8:54am  Quote
Nicely done!
Can't never did anything!
Posted: September/18/2022 at 9:47am  Quote
Really spectacular!
Quote:
...by Joseph N(can’t read the rest)...
Probably Joseph Nieto.
Posted: September/19/2022 at 2:15am  Quote
Thanks guys,
abufletcher, That looks like it would be about right, the bottom half of his last name had been cut off some where along the way.
Steve
Steve.
Avatar User Offline Richo07
Posted: September/19/2022 at 2:48am  Quote
Beautiful ??. Don’t mind if I do!!
Find me on You Tube at 'Just RC'.
Building: BUSA 1/3 Fokker DVII.
On hold: Meister Scale BF109 'G' 1/4, Pica FW 190 'D9' 1/6.
Waiting room: Fokke RC BF 109 'K' 1/4.
Avatar User Offline ramses
Posted: September/28/2022 at 5:55am  Quote
Beautiful Fokker
Very nice paint scheme too!
Cheers, Ramses
Posted: September/28/2022 at 6:52am  Quote
Love the Dvii Steve.....looks fantastic.......
Just out of interest mine weighs 10.5kg...laser 200v...fly's great.....one thing with mine is i have slight down trim on elevator.....fly's in a neutral position which looks great in the sky.....have seen them tail down which doesn't.
Which covering did you use?.....that's the one thing that lets mine down in scale comps.....as no colour photos....all black and white.....
Good luck with the maiden ......sorry you might have done that already if i missed it....
Another thing recently i did on mine was replace the existing bungee with loads more.....stops those wing tips hitting the ground on landings.....since my landings have improved no end...
Cheers
Dave
Fokker D-VI
Fokker DVII
Fokker DVII
Fokker DR-1
