Home>Forums>Show Your Stuff!!!>Sabre Powered Hawker Fury Search Within This Topic
Avatar User Offline Heyluc
Hawker Enthusiast
Posted: January/15/2017 at 12:10am  Quote
Hi All
This is the Hawker Fury with Sabre engine (VP207) almost completed.
Model started life as a Jerry Bates Sea Fury (1/5.6 Scale - 81.25' Wingspan) in 2010 while living in Qatar. Wanted to do something different and found the Sabre engine powered Fury.
Roto 85FSI engine installed, Sierra retracts and Futaba radio (Futaba and Hitec servo's used). Covered with FliteMetal. Have flown it a week ago, prior to finishing the Flitemetal (no video) and it flies as on rails. Weight is 15kg.
Still work to do, like the exhaust stacks and other details that are missing but getting there.
Luc
Avatar User Offline Boltman
Posted: January/15/2017 at 1:10am  Quote
Interesting choice of model. Looks great!
P-47 Composite DLE55
CARF P-47 DLE120
Sig 1/3 Spacewalker DLE35
Krill Extra 330sc DLE130
Avatar User Offline pomroyj
Posted: January/16/2017 at 10:40am  Quote
A flying mirror, wish I had that kind of eye sight still
Beautiful job, just gorgeous!!
John
Flying: CYM Mustang, YA Texan, Hostetler PT-19
Queue: Z-DC3
Chandler, AZ
Avatar User Offline BkSeatFlyr
Posted: January/16/2017 at 5:50pm  Quote
  Hi Luc,
  Your Fury is beautiful & very definitely different ! Never seen one or these before.
 I am interested in the 85 FSI's performance in a 15kg warbird, do you think it pulled the model around well & what prop are you using? how many RPM are you getting on the ground?
   Regards....Bak
Avatar User Offline aeroplane88
Posted: January/16/2017 at 6:08pm  Quote
Beautiful project Luc!
-Lindsay
Avatar User Offline JimHarley
Posted: January/16/2017 at 6:47pm  Quote
Stunning...did you document the flite metal application?
Jim
Current Projects
1/4 Scale Clipped Wing Cub Flying
1/3 Mike Smart Pitts S-1
Hawker Enthusiast
Posted: January/17/2017 at 2:29pm  Quote
Thanks all for your nice comments:
Bak: the Roto runs at 5700rpm with a 25x10 propeller. The plane could use a bit more power but I will see once the engine loses up what the performance will be. Maybe I will install a 25x12 prop.
Jim: I didn't document the flitemetal application, the process took longer then 2 years in part because I have limited time but also it takes that long too apply and I got bored with it a couple of times. I might have some pictures taken during the process. Currently I am on a business trip and will check when home again.
Luc
Posted: January/17/2017 at 8:46pm  Quote
  Hi Luc,
  Thanks for the info, numbers sound good. I believe these engines are run & tuned at the factory, but not run in so it should free up over time. Please update this thread as you get more hours on the engine.
  These engines are now available through a NZ supplier ( no private import hassle's) and I have a project tucked away (13-14kg) that this engine would just fit nicely.
  Thanks again.
   Regards....Bak
Son-Father-Project: Hawker Fury B.Brassey
Source for wheels and gear
Separate Telemetry
Save 30%...Here’s How
