Home>Forums>Scale Stories>Curtiss Headless Pusher Search Within This Topic
Posted: August/24/2015 at 8:40am  Quote
While cleaning out the garage, I found a couple old cane fishing poles. A perfect fit for the rear booms. 1/4 scale, George Marsden plans. Looks like a lot of fittings and silver soldering.
Scratch Jennin Taube
Proctor D7
Toni Clark Sopwith Pup
Flight of the Phoenix
GTM 1/3 Fok EV
Kauffmann No.1
Next: Don Smith Ki-27 Nate
Avatar User Offline 107ch
Posted: August/24/2015 at 11:06am  Quote
Wow, I love that plane! Looks to be way over my head as far as construction goes. I would love to see a build thread on this one, lots to learn. I see that plans are still available too. What will you power it with?
Dennis
Dennis
Ziroli Stuka
Working on: BUSA 1/3 pup
Full size Pitts S-1
Full size Circa Nieuport N-17
Avatar User Offline BobH
Posted: August/24/2015 at 11:09am  Quote
Wow,
that is so cool!!
Richard Crapp
Posted: August/24/2015 at 12:34pm  Quote
   Why is it called a "headless" pusher?
 There have been a replica or two haven't there, are you going to do an original, or an existing subject.
THE 2026 WORLD CHAMPIONSHIP
Vid with new info:
https://worldscale26.bmfa.uk/
Posted: August/24/2015 at 1:13pm  Quote
Dennis,  The plans call for a 120. Having built the Avro D from Marsden's plans which also called for a 120 and I ended up with a Laser 180 in it. I'll probably go with a Laser 150 or 180. Both aircraft are about the same size and have lots of drag.
Richard,  The early pushers had a second elevator mounted on bamboo booms out in front of the pilot. During a flight, a pusher hit a fence breaking off the front elevator. The pilot took off without the front elevator and discovered the aircraft flew much better without the front elevator. The pushers manufactured after that were built without the forward elevator and they were called "Headless".
I was thinking about modeling it after the one called "Sweetheart" in the EAA Museum.
Proctor D7
GTM 1/3 Fok EV
Kauffmann No.1
Posted: August/24/2015 at 2:32pm  Quote
Just curious, how detailed are the plans in regards to all the rigging and fittings? Are the rigging attachments just cut out of aluminum sheeting and then drilled/formed? A fascinating subject. I will be watching this thread with great interest,
Dennis
Dennis
Ziroli Stuka
Full size Pitts S-1
Posted: August/24/2015 at 5:06pm  Quote
Dennis,
The plans are well detailed regarding fittings and rigging. Any fittings that are soldered are shown as brass sheet & tubing. I plan on going with stainless sheet and thin wall stainless tubing which won't melt being silver soldered.
The Marsden plans are from Scale Plans and Photo Service. www.scaleplansusa.com
Proctor D7
GTM 1/3 Fok EV
Kauffmann No.1
Curtis Model D Pusher
Marsden Design Headless Pusher
1/6 Curtiss Model D pusher
Curtiss Hawk P-36
