Home>Forums>Scale Cockpits and Pilots>Who molds canopies? Search Within This Topic
Scale Head
Posted: February/02/2026 at 10:23am  Quote
Does anyone know of a person or a company that can use an existing canopy, make a plug from it without destroying it and then pull more canopies? May take this on myself but I would have to build a Vacu -form table, the plug etc etc. in my spare time (big belly laugh for that one!) Hoping to find someone to take this on, make me a copy in exchange for the use of the original and sell others for a profit for themselves. I have lost my go to person for this. It's for the Tony Lewis Me 410 and is a large two pc canopy. Long shot and thanks in advance.
Posted: February/02/2026 at 11:04am  Quote
Plug has to be a high temp resin... Let me say it must be a high temp resin.
You do not want this to occur during V-forming
Avatar User Offline casor
Posted: February/02/2026 at 11:17am  Quote
Dynamic balsa does large vac formings
You can vac HIPS over a balsa plug, finish it and then make the vac plug by pouring into the HIPS vac Durham's Water Putty, a plaster like material that is much stronger and smoother than regular plaster and which can be finished to a high gloss.  The HIPS vac should be supported to avoid distortion depending on its size
Avatar User Offline pilotjunky
Posted: February/02/2026 at 4:00pm  Quote
I did something similar with a P-40 Top flight kit a number of years ago.  I used Hydrocal from Reynolds Materials. I poured it into the existing kit vacuum form components (including canopy) which created lovely smooth molds.  I didn't use any parting material and they popped out just fine. (I probably used compressed air around the edges).  Then I built one of these https://www.build-stuff.com/plans/hobby-vac-vacuum-forming-b uild-plans/.  It may not be big enough for your project in one piece, but it works great.   If you tried the Hydrocal mold material, at least you'd have the molds.  Been a while but I know it worked and this thread had me discovering the bag of leftover hydrocal in my shop. :-)  This stuff doesn't care about heat either.
Rich.
Rich
Cave Creek, Arizona
Costa Mesa, California
How do you make canopies
WWI plans and kits?
Who does laser cutting of ribs?
3 blades spinners
