| Author / Post |
Camel65  Site Supporter
Still above the daisies!
United States Posts: 207 IP Logged
| Posted: June/02/2026 at 1:21am |
Nice work Bob! It would be handy for post curing composites as well.
__________________ All the Best,
Bill
bhouin  Lifetime Site Supporter
United States Posts: 916 IP Logged
| Posted: June/02/2026 at 7:53am |
Good point Bill. Thanks!
__________________ Bob Houin
Murfreesboro, TN
www.HeritageWingsRC.com
invertmast  Site Supporter
United States Posts: 6421 IP Logged
| Posted: June/02/2026 at 1:32pm |
Very nice Bob!
Would you be willing to pull some canopies in the future if the molds are provided?
__________________ Thomas W.
| Posted: June/03/2026 at 6:58am |
Thomas, I am seriously considering that as an offering.
Murfreesboro, TN
| Posted: June/10/2026 at 12:19pm |
I have been testing the dryer and it is working well. I am able to hold temps as needed for drying. I have found that I needed to make some adjustments to ensure that the heat zone where the heater is doesn't soften the center of the sheet. So, to help with that I added a piece of cement board on top of the metal shelf. I have also added some aluminum reinforced tape to one side to prevent the heat from wrapping around the one side. This allows me to lean the sheet against that wall mostly vertical to provide the best amount of air around it. I will also need to make an adjustment at some point to allow me to use the fan. I am currently using the fan piping to allow the steam to escape, so I will need to add a new approach for the fan (not a big deal at this point). Anyway, in some early tests (prior to some of the changes above), the tests demonstrated clear canopies. Big milestone here. Now I just need to refine the temp/time approaches for each material and thickness prior to forming. Step by step making progress and the end is very near!
I hope you find these updates interesting as I want to ensure that everyone is aware of the progress in getting this line fully back in the market.
Murfreesboro, TN
jetfool  Site Supporter
United States Posts: 590 IP Logged
| Posted: June/10/2026 at 6:03pm |
Great News, Bob Still interested in the HE-219 when you perfect your canapoies.
Best Regards, Rex
| Posted: June/24/2026 at 9:29am |
Process is good now. I am starting to add canopies to the website. So far I have added the Firefly and HE219. Others will be added as I verify the plugs.
Murfreesboro, TN
| Posted: June/25/2026 at 7:07am |
The P66 and SBC4 canopies will be added to the site today. The T-28 and Whirlwind plugs are going to need some work but nothing that a little elbow grease can't solve!
Murfreesboro, TN
