Home>Forums>Introduce Yourself>Hello from Sweden Search Within This Topic
Avatar User Offline F24W
Posted: November/06/2020 at 8:59am  Quote
Hi all,
After a 15 year hiatus I am back into scale building and I enjoy every bit of it. Thank you guys for getting me back on track with your inspiring contributions here on RCSB.
I am posting a picture of the project started 2006  The plane is 1/4-scale, built from enlarged Phillip Kent plans. Landing gear is constructed of steel tubing and modified 1/8-scale buggy shock absorbers. Not sure whether they are up to the task. They are fully compressed at a 20 lb. load each and have a one inch travel. Model weight is roughly estimated to 22 lbs.
A lot of work has been put in the last two months and I am thinking of starting a build thread
Regards, Rune
(with a little help of Google Translate)
Avatar User Offline Henri
Posted: November/06/2020 at 9:14am  Quote
Hi, welcome!
What is it you're building? Fairchild 24?
Posted: November/06/2020 at 9:19am  Quote
Yep, Forgot to mention. F24 with radial cowl
Avatar User Offline N99JH
Posted: November/06/2020 at 9:42am  Quote
Hi Rune
Glad to see you working on the Fairchild F-24W. The F-24R is one of my all time favorites and I have both Hostetler plans and parts, as well, as enlarged plans and short kit for a 1/3 scale version.
I will be retired in less than 2 weeks and may work on one of the F-24R pretty soon than after.
I am going to follow your build thread with much interest.
Cheers
Josh
Posted: November/06/2020 at 10:20am  Quote
Thanks Josh for the kind words.
I am aware of the Hostetler F24 and will probably purchase the wheel pants offered by Fibertech n More. Not exactly the right scale but I think they will be close enough.
Congratulations to your coming retirement.
Rune,
Happily retired since 2017
Posted: November/06/2020 at 10:23am  Quote
Rune;
Welcome to our site. Glad to have you & we wish you best of good luck. If you need any photos of the Fairchild, I’m sure you will find them on the Internet. If you need more close ups, let me know.
Posted: November/06/2020 at 10:27am  Quote
I have the F-24R plans done by the late Steve Sauger. In my opinion these are the most accurate plans ever made. I had them blown to the same scale as Hostetler's so that I can use his Cowl and Wheel pants from Fibertech n More.
Posted: November/06/2020 at 8:30pm  Quote
Welcome, Keep at it we can help along the way.
I think if you land gently the gear will be up to the task but if you are going to bang it into the ground I'd double the shocks or stiffen things up.
Hello from Sweden!
Hello from SC
Hello from Leeds
