Home>Forums>R/C Tools Videos>Ep. 7 - Balsa Strippers Search Within This Topic
Posted: April/02/2018 at 5:34pm  Quote
Join me in my shop as I talk about tools used by scale builders. This episode, I show how balsa strippers work for those that have never used one.
You can find more information on these tools:
Master Airscrew Balsa Stripper
https://amzn.to/3byoCOZ
Xacto Balsa Stripper
(Discontinued but you might find one on eBay or a local hobby shop)
Avatar User Offline dirkske
Posted: April/02/2018 at 11:57pm  Quote
For those with a 3d printer, put it to use and print a stripper for each relevant strip width. Search Thingiverse ex: https://www.thingiverse.com/thing:1892640
Avatar User Offline lovetoflyguy
Posted: December/14/2018 at 8:03pm  Quote
I was so excited about this post.....differen't kind of stripper...
Warbird Alley
Big Sexy Aviation
Avatar User Offline Bentwings
Posted: February/14/2021 at 6:23pm  Quote
I’m going to just add a tip I didn’t see spoken about.
I’ve yet to see a perfectly straight balsa flat. The edge curvature is called camber. Be it wood metal or other supposedly straight material. So you go to the home store and ask for an aluminum straight edge about 3-4 feet long . Yes a yard stick is one name but in machine shop and other shop it’s called a scale or rule. Not ruler. It’s like motors and engines. Strictly shop talk.
So get one of these straight edges preferably an anodized one, mainly because they have slightly rounded edges and are just a little harder.2” wide seemed best for me but I’ll go through the whole display looking for the one with the least camber. Dead straight is the “keeper one.
Now to use this carefully bought piece.
The project I’d to start lsying the planking or making parts with dead straight edges.
Tak the chosen balso flat stock and lay it flat on the table. , wiggle the straight edge of the sluminum so it has about equal amounts to be trimmed off the sheet on each edge. You may want to clamp it down. Then take your exacto knif with a new #11 blade and slice the edge if the balsa sheet. This now gives you a working edge.
Using you stripper again new #11 blade and cut strips what ever width you like. I use about 3/8” wide for fuselage and nacelle covering. Usually you can cut a number of strips before retriming .
I’ve tried angle cuttin to make tighter seams but I just never seem to get good results. I use yellow glue as it sands easy when hard. I don’t use CA excep to stick them to bulkheads as it is very hard to sand.a little water and ammonia works wonders for shaping too. I don’t do sheets when planking as it’s too hard to hold alignment. I think this is old school but it sure works for me.
I’ve seen dollhouse builders do this with ship lap sides that were so perfect it was scary.
Byron
Th
Lifetime builder
Avatar User Offline Russell Willis
Posted: March/09/2023 at 3:29am  Quote
Good advice all.
Avatar User Offline Arngeir Blakseth
Posted: March/09/2023 at 3:59am  Quote
Best balsa stripper I have tried is one I bought from SLEC in the UK  few years back. It includes a 1m long aluminium U-channel that you attach to your bench or even better a piece of melamin faced chipboard. Your balsa sheet is held in position along this and that makes it easy to strip balsa and maintain a straight edge. It also is useful for checking how straight your balsa sheet is before you start stripping, many sheets do have a less than perfectly straight edge to them.
McLeod Balsa Stripper
Dan McLeod Balsa Stripper??
Ep. 5 - BVM Clevis Pliers
Ep. 9 - Plan Storage
