Home>Forums>Introduce Yourself>Hi From South Africa Search Within This Topic
Avatar User Offline foodstick
Posted: November/19/2015 at 1:43pm  Quote
Tango,
I have been curious about those magnetic building setups... but I know the second I bought one.....
The magnetic poles on the earth would flip !   :P     hahahahahaahah
Avatar User Offline Tango Juliet
Posted: November/19/2015 at 1:56pm  Quote
I prefer it to pushing pins or nails, but if that's what you're used to, it would take some time to adjust I'm sure.  I've been using magnets for 25 years now.  I only recently upgraded to a bigger set and larger metal bench top.
TJ Rohyans - L.A. (Lower Alabama)
On The Board - Chris Williams 1/3.5 Slingsby Sedbergh T21b
Member In Good Standing - Builders Slower Than A Dead Turtle Nailed To A Fencepost Association
Posted: November/19/2015 at 2:05pm  Quote
       I think if I wasn't allergic to CA it would be a cool way to go... I would have to put steel all over everything I own downstairs as I tend to build everywhere ! Speaking of which I need to do a cleaning day...
Didn't mean to sidetrack things,, but I had to make the joke about the earths magnetic field messing up my building   ..It feels like the first day of winter and I need cheered up !
Posted: November/19/2015 at 3:10pm  Quote
I don't use CA very often any more.  I prefer Titebond II and Super'Phatic.
freeflight
Posted: November/19/2015 at 9:06pm  Quote
Ca's have a place in building and I use it when it's appropriate or need a quick grab. Titebond 11 is a great glue, that's my general assembly glue, if it holds cabinets together it's gotta be good.
I also use 3 different epoxies time wise 5-15 and 30 min. epoxy, something for every thing. I'm a T-pin guy, would be hard to switch to magnets at this late date, I use sheetrock for table tops and really like it.
Just saying
1/5 TF mustang
Sig 1/4 spacewalker'
Balsa 1/4 scale super cub
Avatar User Offline Ulema
National Flag of South Africa South Africa
Posted: November/20/2015 at 6:45am  Quote
This is my first build and  liked the idea of using magnets, i know that there will be times where i will use pins as well to make the job more easy.
I would like to have a look at the datasheets of Titebond II to see if i can find something similar in South Africa, very nice to get some suggestions from you guys.
I will start the build thread of the Cessna in the TopFlight forum next month, i need to finish the 3d printer next week to print some parts i will need for the Cessna.
Posted: November/20/2015 at 6:48am  Quote
See if this helps in your search.
Posted: November/20/2015 at 6:56am  Quote
Thanks TJ Googled Ponal Adhesives SA found something similar
Hi from South Africa
Hello from South Africa
New member from South Africa
